99 sephia, Check engine light, O/D off flashing + 5 codes - Kia Forum
post #1 of 6 (permalink) Old 06-21-2010, 08:32 PM Thread Starter
Help, I have a 1999 Sephia. Runs good, but I have a check engine light and O/D off light flashing. If I disconnect the computer and plug it back in, the light will stay off for a period, then come back on. Dumped the codes at Auto Zone and got 5 codes.
P 1624 MANUFACTURER CONTROL, AUX INPUTS, AUX OUTPUTS
P 1614 SAME AS ABOVE
P 0734 GEAR 4 RATIO INCORRECT
P 1500 MANUF. CONTROL VEH. SPEED
p 0733 GEAR 3 RATION INCORRECT
Any ideas?
sephia777 is offline
post #2 of 6 (permalink) Old 06-22-2010, 12:09 PM
Sounds like you've got some internal trans issues, or a lot of wiring problems. Is there any visible corrosion at the connectors on the trans?
mattybyzf is offline
post #3 of 6 (permalink) Old 06-22-2010, 07:14 PM Thread Starter
No corrosion at the connectors and I cleaned powertrain grounds.
post #4 of 6 (permalink) Old 06-26-2010, 07:21 PM
cammac1989's Avatar
Drives: kia sorento, sephia, nissan maxima
same problem, its been doing it for about a year, probably about once a month all i do is reset the computer and it will go away...
cammac1989 is offline
post #5 of 6 (permalink) Old 06-26-2010, 10:19 PM
DavesSpectra's Avatar
Quoted: 352 Post(s)
Sounds like the O/D shift solenoid may be int hanging up. read this post....
99 kia sephia, o/d light is flashing on dash - FixYa
Another posibility....found on the web....
My O/D off indicator light was flashing, and I found a part on the fire wall that has a few electrical wires and two vacuum hoses attached to it, one of the connectors for the hoses was broken, when I rigged the hose to stay connected, ( couldn't just buy the part, because I have yet to find anyone that knows what it is) the O/D light quit flashing and my O/D button on my gear shift started working
Again "Thanks Google!"
DavesSpectra is offline
post #6 of 6 (permalink) Old 06-26-2010, 10:23 PM
Quoted: 352 Post(s)
Found another possible cause......
WikiAnswers - What does it mean when the O D OFF indicator light flashes on a 1999 Kia Sephia
Ref:try replacing your vehicle speed sensor in the transmission, that should take care of the problem.
Keep us posted
