2000 Sephia headlight problem - Kia Forum
Go Back   Kia Forum > KIA Models > Kia Sephia Forum > 2G (1998 - 2001) Sephia
Old 02-23-2010, 10:18 PM   #1 (permalink)
Drives: 2000 Kia Sephia LS
Gallery: 9
Default 2000 Sephia headlight problem
Hi all,
My first post here and need some advice/help on a problem that started to happen recently with my 2000 Sephia.
I recently changed the spark plugs after I found out that one was loose and another one had a bent terminal.
Now the day after I changed them, I started to have problems with my headlights. They are way too dim for me to drive at night and requires me to use the high beams.
After this happened, the airbag light came on and the engine temperature went up slightly.
Before I changed the plugs, I did change the alternator last month after the old one went AWOL on me and left me stranded one night while going to work.
My car has 121,310 miles if it helps in any way. Any help is appreciated.
Sephia2000 is offline   Reply With Quote
Old 02-24-2010, 07:24 AM   #2 (permalink)
Well, these other issues don't sound related the headlight issue. Check the grounds for the headlights for rust/corrosion/paint where they bolt to the body. Also, check the headlight connector itself. I've seen plenty where the connector melts and damages the ground terminal in the connector.
mattybyzf is offline   Reply With Quote
Old 02-27-2010, 07:49 AM   #3 (permalink)
Gallery: 9
Well I took my car to the local autozone and these are the codes that were pulled from the OBDII:
PO732 (Low XMSN fluid level, improper 2nd gear ratio)
PO560
PO128 (Low coolant level...I refilled the radiator the other day)
PO1624 (Cooling fan relay failure...although my fan does still run, but too fast)
The girl at autozone told me that I may have a faulty PCM...not sure how much is involved or if I might be able to get a replacement.
I'll get the easier codes fixed, just need some pointers on the PCM and how to obtain one.
George A.Arana
Newark,Delaware.USA
2000 Kia Sephia LS
Old 02-27-2010, 09:56 AM   #4 (permalink)
PLP
Moderator
PLP's Avatar
yes, it would an easy-kia service-way to simply replace ECU/PCM and anything else before trying to figure out what the cause really is.
as it was said above - check all grounds. Refer to kia tech info (link below) to localize all ground connectors.
Also, purchase a multimeter so that you can check voltage at headlights. Also, check voltage at battery terminals when engine is on (idle) and off. Could be you get to low voltage (alternator problem? engine ground problem?).
Most of the time errors as provided have to do with low voltage/ground problem than PCM itself. If it was broken - you would have more problems.
www.kiatechinfo.com USA - free service, manualsgsw-kia.ca/index_eng.asp Canada www.kia-hotline.com Europe (paid service!) www.kia.ca/pages/owner/OwnersManual.aspx?lang=en manuals - must pick model, Canadian version - for free
