why reverse light stay on
11K views 13 replies 2 participants last post by  mohamed mosaad
#1 · (Edited by Moderator)
Hi all i have problem in my reverse light stay on when i turn on my car any help please
#10 ·
To get things correct, if you disconnected connector from the reverse switch and the lights still do not shut off,then the switch is OKAY.And the trouble is in wiring. Is this a manual or automatic transmission?And do you have any other lights turned on that would work(turn on) any of the other tail lights while the reverse lights are on? I can not tell you where the power is the is shorting into the reverse light wiring is, you will need to inspect the wires from the reverse switch back to the lights to find the problem.
