Hi
What are the symptoms of a clutch damage after road is crowd i find no response acceleration when i press the accelerator and RBM go up and no speed
And any one can tell me if i need to buy new one how i find it on ebay
If the engine's RPM goes up and your car doesn't move while in gear, sounds like the Clutch is Slipping or also it could have a broken constant velocity joint.
I kindly suggest you to let a mechanic to check your Sephia, to be sure what is causing the problem, otherwise you might be buying parts that your car doesn't need.
the car move but no fast response this is happened before and i replace the clutch and every thing was good for 9 month the problem appear again now so in think the clutch in egypt not good (Seco Clutch ) and the other one valeo not good too so i need to buy one from outside egypt can you help me in this
If a clutch lasts only 9 months on a car that the same driver drove for 7 years on the original clutch, then it would not be normal, and points to a number of possibilities such as incorrect installation, oil leaking onto clutch, or poor quality clutch kit.
