Hello everyone! I have a brain teaser that has me scratching.
I have owned my Kia for about 2 years. Replaced water pump and all the belts when we first bought it. Replaced the tires, plugs, and wires about 6 months ago.
About a month ago it starts having issues shifting. Bullet points for easy reading:
This car is mostly an around town car, but it is also our long trip car. When working, we can take this on the road (and have) at 80 for 2+ hours and it runs fine. Get off an exit to get gas, and it starts acting up at the first red light. Reset it and drive another 2+ hours just fine. It does seem to "happen more" when around town then on the road.
Considering it runs fine "when it wants to" i don't believe the trans is shot, but i am not a mechanic and any mechanic I talk to wants to jump to trans first thing. I have tried to read up on everything on the board I can and every time i think i found the solution, the poster in that thread has an issue i didn't, like the speedometer not working, or it never resolving itself.
Any help is much appreciated.
- handles 1st and 2nd usually fine
- When it acts up, As it starts to shift to 3rd it will drop into neutral, the engine will rev, I let off the gas. Then it will either go into 3rd or stay in 2nd.
- If it stays in 2nd, every time you press the gas more than a small amount it drops to neutral and revs again.
- If it goes into 3rd, everything is fine until the next time I stop and it moves to 1st/2nd.
- I can pull the battery after it acts up, and it will work again, but with diminishing returns. First it resolved for a couple of days, then a day, now its minutes before it does it again.
- Sometimes shifting to neutral while in motion, turning the car off and back on, then shifting back resolves it, but not always.
- It does work fine from time to time with no issues.
- Hooked it to code reader, and get P0733/P0734
- When acting up, Check engine light is on and O/D Off Flashes. When fine, both are off.
- When acting up it shifts into 1st very hard, shaking the car and almost killing the engine
- All fluid levels are good
- Speedometer and tach are working fine
