How-to tips: Install Curt Trailer Hitch and Wiring Harness on 2016 Sorento - Kia Forum
 18Likes
post #1 of 75 (permalink) Old 01-21-2016, 05:36 PM Thread Starter
Quoted: 4 Post(s)
Arrow How-to tips: Install Curt Trailer Hitch and Wiring Harness on 2016 Sorento
Pictures: Sorento Trailer Hitch Install by bikepoet | Photobucket
This really isn't a full how-to, more like a tips to the already included instructions.
Hitch: This was pretty easy as far as car stuff goes. The included instructions are great. Before installing the hitch, I used some rustoleum paint to touch-up the chipped places on the hitch. You will need a coin to unscrew the cover for the spare tire lowering cable. And I think itís a 19mm, so I used a ratchet and extension. Like others have mentioned, I put the passenger side up on the exhaust, and then screwed in the M10 bolt on the driverís side. I didnít have to remove the frame plug from the driverís side, too. It was really tough to get 110 lb-ft on the 17mm nuts even using my ĹĒ torque wrench.
Wiring harness: I installed the wiring harness box on top of the metal bumper, using the included double-sided tape and added a zip tie to the included zip tie to also hold it down. I had some extra wiring harness loom to put around the 4 bare wires, too. I snapped some pictures in case anyone is interested.
bikepoet is offline
post #2 of 75 (permalink) Old 01-24-2016, 03:29 PM
Quoted: 10 Post(s)
Installed the Curt hitch yesterday. Easy if you have some mechanical aptitude and follow the instructions. A little difficult to position the hitch by yourself. A little more if laying on your back. E trailer has installation videos as well. Am going to install the wiring next weekend. The plug and play kit. Check for the connectors and get the correct wiring kit. The spare winch "nut" on our Sorento is 21mm. I ran the bolts in the threaded holes before installation. Had to chase one hole with a tap to clean the threads. The rear horizontal bolt on right/passenger side needed some "persuasion" to install as the hitch plate was impeded by the weld for the muffler hanger. Took about an hour to complete install. I like the Curt's extra weight rating. Wish it had a bracket to mount the wiring connector. Installed on 2.0 Turbo AWD.
dardsa likes this.
Our 2016 Sorento-Assembled in USA!
Engine from USA! Transmission from USA!
53% of the parts-North American!
ntrsandman is offline
post #3 of 75 (permalink) Old 01-24-2016, 05:35 PM
Drives: 2016 KIA Sorento EX AWD 2.0T w/Prem Pkg
Quoted: 34 Post(s)
What did you mean by "Like others have mentioned, I put the passenger side up on the exhaust, and then screwed in the M10 bolt on the driver’s side." ?
Goldbadge is offline
post #4 of 75 (permalink) Old 01-24-2016, 07:54 PM
Quoted: 10 Post(s)
Originally Posted by Goldbadge View Post
What did you mean by "Like others have mentioned, I put the passenger side up on the exhaust, and then screwed in the M10 bolt on the driverís side." ?
The rear/tailpipe section of the exhaust needs to be lowered to install the hitch. Propping the hitch on top of the lowered exhaust makes it easier to align the hitch to the left side mounting area to get bolts started.
Goldbadge likes this.
post #5 of 75 (permalink) Old 03-23-2016, 03:32 PM
ImStricken06's Avatar
Drives: 2016 Sorento, 2013 Santa Fe
Quoted: 127 Post(s)
ordered my hitch last night. also got the wiring kit (for cars without factory towing). stay tuned for the videos to come.
No information posted shall create or express any guarantee of any particular result. For entertainment use only!
ImStricken06 is offline
post #6 of 75 (permalink) Old 03-23-2016, 06:38 PM
Drives: 2016 Sorento SXL V6
Quoted: 13 Post(s)
I was under the impression they were pre-wired to the back somewhere and just needed to finish it off more or less. Are only certain models pre-wired?
Kia007 is offline
post #7 of 75 (permalink) Old 03-23-2016, 08:17 PM
Quoted: 7 Post(s)
Check out the trailers site and videos.
pilotmass is offline
post #8 of 75 (permalink) Old 03-23-2016, 10:02 PM
Quoted: 127 Post(s)
not all cars. my LX do not come with that pre-wiring.
post #9 of 75 (permalink) Old 03-23-2016, 10:04 PM
Quoted: 127 Post(s)
Curt, is the best hitch on the market. you will see in my video why
buy it here:
Amazon.com: CURT Manufacturing 13195 Class III 2 in. Receiver Hitch: Automotive Amazon.com: CURT Manufacturing 13195 Class III 2 in. Receiver Hitch: Automotive
Wiring connector kit (for those who dont have pre-wired cars)
buy it here:
Amazon.com: CURT 56256 Custom Vehicle-to-Trailer Connector: Automotive Amazon.com: CURT 56256 Custom Vehicle-to-Trailer Connector: Automotive
post #10 of 75 (permalink) Old 03-24-2016, 06:41 AM
SXdriver's Avatar
Drives: 2016 Sorento SX 2.0T
Quoted: 45 Post(s)
Thanks for the info on the hitch install. I plan on undercoating my hitch to keep it from rusting. Mine is going in next Tuesday to have the factory hitch installed by the dealer. It was part of the original sales agreement. Apparently, the V6 SX comes with a wiring harness pre installed but the Turbo does not. The hitch was in stock but there was a long delay in getting the harness ordered in. I hope they do a proper job on the harness install. The Mazda dealer installed it wrong on my cx5, causing it to get against the exhaust system, melt and short out. Thankfully the fuse did it's job. They installed a new harness. That was typical of my experience with that dealer. I almost always had to go back and get something done a second time.
dardsa likes this.
SXdriver is offline
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
