Can anyone with new 2016 sorento tell me if the DRl dim`s when using the corresponding turn signal?
As here in the UK they don`t but wondering if its a programming fix.
Thanks in advance.
Looks like you guys in the states don't get day time running light`s, do the Canadian sorentos get them and do the dim or go out if you use the turn signal ?
all Canadian Sorento's have DRL's its been mandatory on all vehicles sold in Canada for the last 25 years.
Don't know for sure but I don't think think they change when you use the turn signal, I know it does on some Chrysler products but I think it all depends on where the DRL's are located in relation to the turn signal light as to whether the DRL's will "wash out" the view of the turn signal so you can't see it clearly.
Thanks for your reply, so any Canadian 2016 sorento owners confirm if day time running lights go out when you indicate as our uk version DRL`s stay full with turn signal`s on
Coming late to the party. Canadian Sorentos run the DRL on the high beams at reduced voltage. They stay on regardless you signal or not, even if you turn on the parking lights (positioning led lighs) they will stay on...Until you turn on the low beams, then they go off.
