I searched all over the internet and i cant find the information. Can someone help me out ! ? Im sure there's probably already a thread on this. Also wich other brands and models would fit on my 15 sorento.... Im about to buy a used winter wheels-tires kit and I want to know my options ! Thank you
Don't know but here's how you can find out. Go to a tire site (tirerack?) and shop for wheels. Then see if the same wheels are options for both the 2011 and 2015. If so, then the OEM 2011 should fit the 2015!
Another option would be to simply find a 2011 on a lot, measure the spacing and offset, and then yours.
Finally, I would think aftermarket wheels would be cheaper than OEM 2011, unless coming off a wreck?
2015 Sorento
Bolt pattern: 5x114.3
Hub bore: 67.1 mm
for my SX wheels, I have:
19x7.5
+50 offset
For aftermarket wheels, try not to get an offset lower than +40 as you might introduce rubbing.
In reference, I have a winter wheel setup of 18x8 with a +45mm offset and it only has mm away from the calipers, but still not poking out of the fenders.
Thank you for your answer. Do you Know if 11-13 sorento's wheels got the same Bolt pattern (5x114, CB 67.1, offset 50)? The reason for my question is that theres plenty of used winter wheels-tires package on the market for the 11-13 modèles and i want to be sure that they Will fit my 2015 Sorento.
