I'm running the latest version of both app & UVO in my 2015 Sorento. No issue with Bluetooth connect and data transfers. I have noticed that the street numbers are stripped from POI addresses sent from Google maps. Not sure if this is on Google or UVO but a work around would be a change to the app that would allow the POIs in the app to be edited prior to being transferred to the car. Until then, the utility of sending a destination to the car in advance is not available as the street is without a specific address which is required for navigation.
I've added an example of what is being sent from Google Maps to the app. The address used in the example is relatively long but even really short addresses; i.e., 123 Main St, are stripped of the "123". I also have noticed that the custom tag field is added as a note so there is no way to use that field to help edit the POI once it is sent to the car as notes are not transferred.
If you have noticed the same issue with the app, please send a message to: myuvosupport@kiausa.com, as they are the contact for app issues.
http://www.kia-forums.com/car-audio...ntion-please-read-before-posting-section.html
