Stuck Oil Filter Cap - Kia Forum
post #1 of 4 (permalink) Old 07-01-2013, 12:26 PM Thread Starter
Drives: 2012 Kia Sorento V6
Hello, new to the forums here but I have searched the other oil filter threads with no luck on a solution for my problem.
I have a 2011 Kia Sorento that I'm trying to change the oil filter in. The filter cap is on there so tight nothing seems to be working for me. I have tried a adjustable crescent wrench, a 27mm box wrench, a adjustable oil filter wrench, and nothing seems to budge it. Is there a special socket or cap wrench for this like some other cars have?
The O-ring appears to be pinched between the housing and the cap, I'm not sure if that has anything to do with it.
I would like to try some of suggestions I might receive on here before I take it to the dealer and have them get it off.
Thanks in advance.
1sorento1 is offline
post #2 of 4 (permalink) Old 07-01-2013, 09:33 PM
Banned
Drives: 2013 Sorento EX V6 AWD
Gallery: 5
Quoted: 23 Post(s)
Apply more force. It will come off. When you replace the filter, make sure you put a couple of drops of oil on your finger and lube up the new o-ring before you put the cap back on.
Sauron is offline
post #3 of 4 (permalink) Old 06-28-2016, 10:31 PM
Drives: 2012 Kia Sorento SX V6
I have this same problem with the pinched o ring. I've tried all the tools the op has mentioned and nothing. The top nut has also become stripped.... I've purchased a replacement but I just need to get this cap off. any suggestions?
Peter Gomez is offline
post #4 of 4 (permalink) Old 06-29-2016, 12:20 PM
Okay. Just solved it. Hopefully this will help someone browsing through the forums for this problem as well. Notice the original poster said that the o ring was pinched between the cap and the housing. Mine was like this as well. I simply pulled the o ring out with what I could then turned the cap with vice grips. Once I pulled everything out, the original o ring was still in place and the one I had pulled out was one that was likely put in all the way to the top or something instead of being used to replace the original.
