I have replaced pads myself many times and do not usually resurface or replace rotors unless they are scored or warped. I know there are different opinions on this, but I never had a problem.
I know some people do this, but I don't recommend it. It's too much of a PITA for most DIY types to check the minimum rotor thickness and more times than not, you'll wind up with vibrations and brake squeal as the new flat pads try to seat into the uneven surface on the old rotor.
IMO, Me neither, and I've never had a problem. Of course I know it's the "redneck" way,,,lol, but why take the original temper out of the rotor if there's nothing wrong?
If it's a fairly new vehicle, you can be pretty sure the rotor has enough meat on it, it's not worn down too much. Besides, the yokel who is doing the machining, may make it worse.
Plus, a couple of days in rainy weather, and your rotors will build up a coating of rust to help you break them in as is.
Another thing, a lot of your big name brake companies are making brakes overseas now, so you can't depend on them being better because of their name anymore.
What we need is a fair independent rating system on brakes nowadays, like they do for tires. I'm sure these are just as important as tires, if not more so!
Previously a 2010 Tucson GLS AWD Kiwi Green
2005 Tucson LX V6 AWD Nautical blue, & a
2002 Santa Fe LX V6 4WD Crystal blue.
Drives: 2012 Sorento SX,Shelby Cobra GT500,'12 Nissan Sentra,'09 Ford Focus
Gallery:
0
Originally Posted by ukrik
Hey guys,
It is time on my sorento 2011 to replace brakes and i would like to know if there is really good aftermarket brakes i can get. The original are too pricey, dealership is asking about $600 installed just for the front, which is really expensive i beleive, everybody tells me i can replace all 4 of the them with better parts gor this price.
I need a suggestion if somebody already installed aftermarket ones, what brand, price and performance. I heard i can get ceramic ones as well....
Some say i should use original parts..
need opinion...
To bad you live so far I'd help you get them done, they're a BREEZE to change...find a WRENCHER in your area and get aftermarket from Canadian Tire or CarQuest, Rotors and CERAMIC Pads shouldn't cost you more than $150 - $200/per axle tops for a mid quality, if I'm not mistaken OE are Ceramic...check out link;
You should take front and rear calipers and pads off every spring and fall to clean and lube SLIDES & PINS when you change over your tires summer to winter...your brakes will last twice as long when properly taken of, takes an extra 1/2 hour or so to do.
Pearl White 2012 SX AWD V6
Auto Start, Hitch
I was trying to call and order them separatelly from Dealership, for Rotors is $170 each and around $80 for brake pads. I have a friend who is a mechanic and he called them to ask with a discounted price and the best they can get them is like $20 off. Redicilous.
Those price are way to expensive. If you need new brake, just let me know and I'd be glad to help you out.
Don't get hung up on "ceramic" in the brake pad description. Many pads have some percentage of ceramic material in them even if they aren't labeled as that. Buy the pads from a trusted maker where the total description of the pads best meets your needs. More: Brake Tech - Why Ceramic Brake Pads?
Temper in cast iron brake discs??? Yes, the discs are cast iron. If they are not appreciably grooved or worn down, they can be lightly sanded to remove any build up of pad material, cleaned with brake cleaner, and re used. Many discs are disposable, though--made thin to save weight (and cost) and soft to improve braking. If they're worn, recycle them at a scrap yard and buy new. By the way, most brake judder is not warped discs but is actually uneven deposits of brake pad material. -Warped- Brake Disc and Other Myths
Okies...I had a father-in-law who was an Okie, and he said that the great Okie migration to California in the '30s raised the I.Q. of both states. I'm from California.
Just purchased Rotors and Brakes from Steve:
PosiQuiet Ceramic Pads
Premium slotted rotors
Everything with shipping to Canada $245
Will keep you posted on the result. Hope everything should be fine, if i like it i will buy for the rear one as well.
Alright here is the update.
Received brakes and pads 3 days later, fast shipping, paid about $18 on taxes/duties. Installed them with local mechanic for $60, and here we go, works and looks great, my mechanic was impressed with he quality, no noise, smooth braking, cannot complain. So far so good, i will get the same set for the back as well close to spring time. So if anyone wants to save money use r1concepts, its tested now... BTW Ebay has thousands of positive feedback on this brand as well..
My Sorento has about 60,000 so original front brakes hold up pretty good for this distance, mechanic said heavier cars worn brake faster. My rear still has about 20% left.
