Galaxy s2 and sorento phonebook - Kia Forum
post #1 of 11 (permalink) Old 10-18-2011, 04:48 PM Thread Starter
Drives: 2011 Sorento SX, 1969 plymouth satellite convertible
I have a SX with the nav system, and changed my phone from a blackberry to the new samsung galaxy s2. Now when I start the car, the bluetooth connects, I get a message on the phone screen that says "phonebook requested" for a second, but there are never any phonebook entries on the nav system. I can make calls with the dial pad, and receive them fine, but no contacts list. Anyone find a solution for this? I found no settings on the phone to allow any permissions for the phonebook. Thanks!
amigafin is offline
post #2 of 11 (permalink) Old 10-18-2011, 07:53 PM
VIM
Drives: White 2012 SX AWD
Quoted: 33 Post(s)
With my Nexus (Android), first time connecting it asked for permission for phone book access on my phone. I saw an icon in notification area otherwise i would not have noticed it.
VIM is offline
post #3 of 11 (permalink) Old 10-18-2011, 08:57 PM
rndman's Avatar
Drives: 2012 Sorento SX-V6 FWD, Nissan Quest 1996, Hyundai Elantra 2000
Gallery: 4
I have a related (but may be little OT) question.
Has anyone paired their Samsung Intercept (Virgin Mobile) in Sorento.
I know there is list of supported devices and I did not find the intercept in that list.
I have this phone and would be buying Sorento soon. Not that I will change either of it just for this reason, but just wanted to know if someone is already using it.
rndman is offline
post #4 of 11 (permalink) Old 10-18-2011, 08:59 PM
Sorento Guy's Avatar
Drives: 2012 Kia Sorento EX
Don't know the answer, but when I was looking to buy mine the salesman let me try out pairing the phone just to see how it worked. You could ask.
Sorento Guy is offline
post #5 of 11 (permalink) Old 10-19-2011, 06:53 PM Thread Starter
Thanks Vim! that worked. If anyone wants to know the entire procedure it went like this:
Delete the bluetooth pairing on the sorento and phone to start from scratch.
Tell the sorento to add a phone, and the phone to search for devices.
Enter the passcode key 0000 and quickly go to your notification area on your phone.
A message will pop up asking for permission to load the phonebook.
Click the checkmark "always allow" and OK (sometimes ok first then "always allow")
Done!
amigafin is offline
post #6 of 11 (permalink) Old 10-19-2011, 08:20 PM
rndman's Avatar
Gallery: 4
Sounds like a plan. Thank you..
rndman is offline
post #7 of 11 (permalink) Old 10-20-2011, 11:27 AM
Drives: 2011 Sorento SX AWD w/ Sunroof(s), 2007 Green Pontiac Solstice 2.4L Blk/Blk
amigafin, Thanks for the verification that the Galaxy IIS works with our Sx's. That’s the Nav, not the UVO (don’t know about it for sure but it should be the same). I tried starting a post with all the newest mobile devices and whether or not they work well but it didn’t take. On another note, I've responded to this issue before so I'll say it again so others who are searching can find the answer. ALL Android devices will initially ask for permission to sync contacts. It shows up in the notification bar when paired, just thumb down the notification and select yes or sync or ok etc... Once this is done no other syncing is needed. If you have an issue "Connecting" after you have "Paired" the device, press the phone button on the KIA, select "Settings" and click on connect. This will force a connect; otherwise the KIA should connect automatically if your Bluetooth is switched on. On Android devices, if the car/suv is connected and you cannot or don’t want to use the hands free, simply use the device to answer and it should route the call through the handset. Also, there is a Bluetooth button on the call screen, if lit, pressing will also route through the handset. If anyone else has a NEW device please post radio and compatibility. Thanks to all of you for NOT texting while driving and for using your Hands-Free function.
Thrillion is offline
post #8 of 11 (permalink) Old 10-22-2011, 07:54 PM
rndman's Avatar
Gallery: 4
Tried the pairing of Samsung Intercept (VM) with Sorento when I went for test drive today. It worked perfectly..
rndman is offline
post #9 of 11 (permalink) Old 10-23-2011, 08:51 PM
Munchausen's Avatar
Drives: '02 Kia Spectra, '11 Sorento Dark Cherry EX AWD V6
Gallery: 5
Just got a Galaxy S2 (AT&T) myself.. it paired with ours with no problem.. but yeah I too had to look at the phone to give it the ok to let the car see my contacts (Never had to do that with my N1..odd).
Glad everything works for ya
Munchausen is offline
post #10 of 11 (permalink) Old 06-12-2012, 02:28 PM
vix
Contacts - SIM to phone
Originally Posted by Thrillion View Post
amigafin, Thanks for the verification that the Galaxy IIS works with our Sx's. Thatís the Nav, not the UVO (donít know about it for sure but it should be the same). I tried starting a post with all the newest mobile devices and whether or not they work well but it didnít take. On another note, I've responded to this issue before so I'll say it again so others who are searching can find the answer. ALL Android devices will initially ask for permission to sync contacts. It shows up in the notification bar when paired, just thumb down the notification and select yes or sync or ok etc... Once this is done no other syncing is needed. If you have an issue "Connecting" after you have "Paired" the device, press the phone button on the KIA, select "Settings" and click on connect. This will force a connect; otherwise the KIA should connect automatically if your Bluetooth is switched on. On Android devices, if the car/suv is connected and you cannot or donít want to use the hands free, simply use the device to answer and it should route the call through the handset. Also, there is a Bluetooth button on the call screen, if lit, pressing will also route through the handset. If anyone else has a NEW device please post radio and compatibility. Thanks to all of you for NOT texting while driving and for using your Hands-Free function.
Just got a Galaxy Ace and still had trouble getting the contacts visible in my Sportage even though I was able to pair successfully. Resolved by saving all my SIM contacts to the phone.
vix is offline
