Just another note on the front end pulling problems.Before any alignment adjustments are made to correct a pull condition ,you must be certain that the pull is not caused by a faulty tire.Switch the tires around front to back and side to side and test drive the car.If at any time a tire switch eliminates the pull or the pull goes the opposite direction,you need a new tire or multiple new tires,not an alignment.A brand new radial tire,if manufactured improperly,can cause a pretty serious pull or drift.
Sorento XM manual trans subgroop member #1
Reason: grammar
