Hi. I was changing the reverse bulb as i was on a hill i put the e-brake all the way down just so i can make sure bulb was lighting up. as i went back to put it on drive the vehicle shut off. Now doesn't let me put kia into park or reverse, doesn't start at all
Describe "won't go into". Does the shifter move owes the and mission not actually shift? If the first, stomp hard on the brake to make sure the shift interlock is being activated. Alternately pry the little plastic cover up that's directly in front of the shifter and push your key into it to bypass the interlock and shift it into park.
Sometimes when I pull into the garage, I forget to shift into park and push the button to shut it off. DUH!!! Gear selector will not move. Then I have to push the button/brake to start and then can shift it into park
