2003 Sorento 2wd 3.5L Gas EX - Kia Forum
Old 02-25-2013, 12:22 PM   #1 (permalink)
tnt580's Avatar
Question 2003 Sorento 2wd 3.5L Gas EX
My 2003 Sorento was running OK, it does have some bad u-joints/ which I understand is not serviceable...however that is not the issue at this point ,
It died while I was driving, I wasn't going much more than 20mph as I had just stopped at an intersection shortly before. I have checked the fuel pump and it seems to pumping out fuel, and the timing belt seems to still be in place, though I have not removed all of the covers to check completely...
I have looked through this site, and at this point I am hoping that it may be a sensor that has failed, and not the timing belt....
Any suggestions would be much help....
just a side not, I am aprox. 100 miles away from any KIA dealer or service department so taking it to them to diagnose it is not so simple.
tnt580 is offline   Reply With Quote
Old 02-25-2013, 12:55 PM   #2 (permalink)
Drives: 05 Kia Sorento LX 4x4
If it stopped like the key was turned off, it could well be a sensor issue. There are reports of the cam/crank sensors going bad causing random stalling out (usually able to start once the computer clears out after a while or things cool down). You didn't give your mileage or when the timing belt was changed last either. If any codes were thrown, it would help US a lot if you could tell us the results (or even if the light came on).
'05 Sorento LX 4x4. Purchased 9-14-11 43,800mi. "Karinka"
'08 Spectra EX 5speed. Purchased 3-25-12 43,500mi. "Saki"
'99 Sephia 5speed "Kurumi". Traded in 2006.
ratsttam is offline   Reply With Quote
Old 02-25-2013, 02:21 PM   #3 (permalink)
Moderator
cobra259's Avatar
Who told you the u/joints are not serviceabul?????? Yes, as far as aftermarket goes they can't get them, but any kia dealership can. I know you ahve much bigger problems now, but when you want to replace them, you can!
cobra259 is online now   Reply With Quote
Old 02-26-2013, 02:19 AM   #4 (permalink)
Drives: 2003 Sorento, 98 Sportage, 1944 Jeep
Must admit it does sound like a cam or probably crank angle sensor. If it stops dead without warning, then restarts after a time, and then usually works OK untill next time it is probably one of these. See if you can get the codes scanned.
cmar is offline   Reply With Quote
Old 02-26-2013, 10:11 AM   #5 (permalink)
Drives: 2003 2WD Sorento LX, 2003 S-10
U-joint sticky
http://www.kia-forums.com/2003-2010-...nents-tsb.html
