Originally Posted by ejazz
I am in the same boat with the crumbling injector connectors. Any part #'s or pics yet? Thanks!
I recieved the pigtails today and it went real well. They fit the injectors very well and lock to them better than the oem ones did. I just had to crimp and solder the metal pins to the wires than slide them in the plug. It took a total of around 30 minutes to do all of them. The link where i found them is,
Set of 6 Nippon Denso Injector Connector Kits for Toyota Blitz Injector Dynamics | eBay . There are quite a few other places that carry this style pigtail also. They are just a standard denso plug. I took some pictures of the process, i will get them loaded onto my computer and post them here in a bit.
Here are some pics of the process i used for this,
I just took a pair of pliers and crushed the old plug off into pieces. From there you are left with 2 pins:
From there i removed the crimped on end:
Next i took the new terminals from this kit, and crimped than soldered them to the end of the wire:
