03 sorento aftermarket radio problems
Ok i am trying to install this radio in my wifes sorento. I have a wiring harness that I have hooked to the radio wires, so far all I have are the speaker wires, constant 12 volt, switched 12 volt, and ground. I hooked it up to the vehicles harness turned it on, everything lit up I could tune to a local station, but I had no sound. I have tried to touch the blue ant. wire from radio to the blue wire from the harness, the harness also has a amp ground wire i have touched it to ground while touching blue wires together and still nothing.
Do any of you have any ideas that I might be able to try?
I do have to add that I do have an amp under the drivers seat.
I have been trying to find a diagram online of the factory harness to make sure the wires are the same from the aftermarket harness, and I have found one but it is hard to read some of the discriptions, what I can read on diagram the speakers wires to both harnesses are not matching up, but the power and ground are in the right place.
I hope I havent confused anyone. If you need more info just ask and I will try to answer as best I can.
Thanks for any help?
