2007 Kia Sorento LX - No Reverse Lights
9K views 3 replies 2 participants last post by  Necrosaro420
#1 · (Edited)
We just bought a 2007 Kia Sorento LX a couple weeks ago from out of state. Today I noticed that the reverse lights are not working. I pulled them out and checked the bulbs and everything was fine. Any idea of what could be wrong with this? I was hoping just a fuse, but I dont even see a reverse light fuse in the manual. I see "EXT Taillight, Turn Signal Light", as well as "Turn Lamp, Turn Signal Light", "Stoplight", Room Lamp etc, but nothing about a reverse light. Thanks
#2 ·
Okay, if the reverse bulbs are okay, you should check if you're getting power to the sockets. The only fuse for the backup lights is the METER fuse. I believe it powers other parts so if it was blown, you would see other issues. There is a relay for backup lamps on the passenger side by the glove box. You should check for power there too. If the relay is good, then you probably have a wiring issue.
