valve cover gasket replacement - Kia Forum
post #1 of 17 (permalink) Old 11-09-2010, 08:24 PM Thread Starter
my wifes 04 ex is weaping oil, and every now and again it gets on exhaust manifold and smells like burnt oil. so... i need top replace v c gasket. is this a diy job? i have done this on old 1.8 vw and 320i bmw. how much needs to be removed to get off the valve cover? has anyone here done this? if it is too much work, how much should i expect to pay to have it done?
thanks in advance
Brandon
04 sorrento
00 jetta
88 ///M3
86 carrera
bmwbevins is offline
post #2 of 17 (permalink) Old 11-09-2010, 08:44 PM
Drives: 04 sedona,94 suburban,97 sephia Tuned & ported
well.......Im not gonna say its a easy job, thats for sure.The complete intake has to come off,and a few other items...............On a scale of 1-10 difficulty for a diy'er.......about a 7 i guess.
Just be carefull with everthing you remove, i see so many sorentos come in with all kinds of broken connectors and sensors from people in to big of a rush.
Items you will need.
VC Gaskets,Coolant,intake Gasket,(Tie Straps<---bound to break a harness holdown clip).....
Dealer LBR hours to do VC gaskets 3.5 hours
replace the spark plugs while your there also,big money saver later
FlatRate572 is offline
post #3 of 17 (permalink) Old 11-10-2010, 09:25 PM Thread Starter
Thanks for the info. I called the dealer, they said i need 2 different gaskets for each valve cover gasket. is this correct? for intake and v c gaskets it was like $160, sound right? Also, can you suggest a repair manual to help? I know i have bought many bentley manuals for german cars, do they make them for kia also?
tia,
brandon
post #4 of 17 (permalink) Old 11-10-2010, 09:30 PM
Quoted: 23 Post(s)
The other gasket may be to seal the spark plug tubes. So yes you would need to different gaskets per VC.
nstoolman1 is offline
post #5 of 17 (permalink) Old 11-10-2010, 10:06 PM Thread Starter
are they rubber gaskets? do i install them dry or with a gasket maker?
post #6 of 17 (permalink) Old 11-10-2010, 11:40 PM
Quoted: 23 Post(s)
Don't know. Have not done them yet. Most gasket sets come with some form of instructions.
post #7 of 17 (permalink) Old 11-11-2010, 12:09 AM
reinaldo's Avatar
Send a message via MSN to reinaldo
Valve Cover Gasket
In your case, I think there is a need to replace that valvce cover gasket. You should call a mechanic in order to do so since it requires a lot of hardwork. If in case you needed to replace many car parts, visit carparts.com
reinaldo is offline
post #8 of 17 (permalink) Old 01-03-2011, 08:10 PM
For the future people i just replaced the valve cover gasket and it sucks.
The manifold has to come off and all the other misc things like hoses and plugs.
After, there's one valve cover bolt located underneath the tops of the timing gear cover (plastic piece) which is only accessible by removing it however... i opted to drill a hole through it to get a socket on it.
food2000 is offline
post #9 of 17 (permalink) Old 03-10-2012, 08:45 PM
Drives: 2003 Kia Sorento EX
The value cover gasket replacement and spark replacement is going to take me about 9 hours. I have 7 hours in it now. It is not hard but it is a long job to complete. On the right value cover, there is one bolt under the front timing chain cover. I cut part of the cover off to get the bolt out and then patched the whole with a piece of hard plastic. If you are going to try this I suggest you get some air tools to speed up the process. There are a lot of bolts to remove. You should also get all the information you can from Youtube and Kiainfotech before giving this a try.
janeskia is offline
post #10 of 17 (permalink) Old 05-12-2014, 06:52 AM
Success
I just did an 06 KIA Sedona valve cover gasket set, spark plugs, and alternator. The oil was weeping onto the alternator which causes it to fail.
It is a serious job. It took me like 8 hours and I am pretty good, plus friends gave me extra hands, so be prepared. The wire harnesses are kind of a pain, but if you can't figure one out, look elsewhere on the vehicle for an example that is easier to get to.
If you're an intermediate DIY mechanic, I encourage you to do this job, but BE PATIENT, commit to acheiving it, and take pictures along the way! You will work it out one step at a time.
fms121 is offline
