P0016 code...possible causes - Kia Forum
post #1 of 9 (permalink) Old 08-03-2010, 08:30 PM Thread Starter
Sorry to start a new thread regarding this, but i just found out what code is triggering the check engine light: P0016 cam crank correlation. What are the possible causes for this? My timing belt, crank gear, harmonic balancer were just replaced. The check engine light was not on prior to this, which leads me to believe that both sensors are good. My buddy who did the work for me said he checked the timing alignment by rotating a full rotation by hand (twice) and that it looked good. He used the specs from Kiatechinfo. Could the timing have gotten off after starting the engine? The vehicle appears to be running fine, although I did notice that it is shifting between gears when 'coasting'. Any advice would be greatly appreciated!! I really hope that we do not have to remove the crank bolt again (hoping we can access the cam through the top cover).
markleyfunk is offline
post #2 of 9 (permalink) Old 08-03-2010, 10:30 PM
maksik's Avatar
Drives: 03'VW Passat - mine | 03'Sorento EX 4X4 - hers
Quoted: 4 Post(s)
1. Were the sensors removed and re-installed, but swapped?
2. Do all timing marks aligned - 4 cams and crank?
3. Check wiring on sensors.
maksik is offline
post #3 of 9 (permalink) Old 08-04-2010, 06:39 AM Thread Starter
NO, the sensors were not removed. The timing marks appeared to be lined up correctly when reinstalled (will double check this today). One thing that crossed my mind...when we removed the crank gear, the sensing plate was completely detached from the gear. After removing this old gear and plate, there was another ring (spacer?) that we may have removed thinking it was part of the gear assembly. Although, I think that the new crank gear may have come with the spacer attached on the back side of the sensing plate..can anyone confirm this?
post #4 of 9 (permalink) Old 08-04-2010, 10:45 AM
maksik's Avatar
Quoted: 4 Post(s)
at this point I would say that is the area that need second look. It is possible that blade was bent or put back reversed - just trying to give you ideas.
Why the crank gear was removed?
maksik is offline
post #5 of 9 (permalink) Old 08-04-2010, 10:57 AM
The sensing blade is part of the crank sprocket. If the blade and sprocket seperated, this could definitely be the cause....
mattybyzf is offline
post #6 of 9 (permalink) Old 08-05-2010, 10:45 PM
Drives: 2006 Sportage
Dont worry about the crank gear, if it was bent you would hear it hitting the crank sensor as it turns around and around. This is more than likely not the case as if it hit the sensor it would probably break it and throw a crank code. It really sounds like the timing is out. The computer checks cam and crank alignment. If it is out a tooth it may seem to be running ok but is not perfect to the computer. Check timing. Oh, one other thing. The holes in the timing cover where the main engine bracket goes on, behind one of the bolt holes is where the wire runs for the crank sensor, I have seen before where guys dont put the wire in the right spot and it gets pinched between the block and the bracket when you tighten the bolts. Also make sure the cam wires are positioned right inside the holder in the timing cover. Keep me posted.
ESKORT27 is offline
post #7 of 9 (permalink) Old 08-06-2010, 04:11 AM
gee6's Avatar
Quoted: 28 Post(s)
Really? So why is it shown as a separate item on the Kiatechinfo diagrams?
Markleyfunk: From what I can see the assembly is
Crank Pulley ---- Sprocket --- Blade ---- Spacer ---- ( Towards Block)
Sensing Blade appears to have a circular ridge which goes towards sprocket and presumably locates it.
File Type: pdf data_Passenger_KM_KMA_ENG_SHOP-Image.pdf (51.0 KB, 1829 views)
gee6 is offline
post #8 of 9 (permalink) Old 08-06-2010, 03:27 PM Thread Starter
Wheew!! So it turns out that it was that the timing was off by one tooth, hence why it was still running fine. Also, my buddy was able to fix it without removing the crank bolt!!
Also, gee6, the sensing blade is part of the crank gear. I think the diagram is just illustrated like that to show the parts, but when you buy a new one, all of that is 'molded' together.
Thanks for all the advice!
post #9 of 9 (permalink) Old 02-13-2016, 12:06 AM
I got this code last week on my Forte 2.0. I've read all the post that I could find on this, and had planned to take my car in for service today actually. The check engine light was on for only 6 days. Well the car wouldn't start so obviously I had it towed to a garage. The engine jumped time and is now shot. If you get this code to anyone who is reading this I cannot say it enough, get it to a garage ASAP!!!! Otherwise you can be like me and spend 2 to 3k on another engine..
smoke101_2005 is offline
