Please Help Asap Re: Sorento Stuck In 4wd Low - Kia Forum
post #1 of 14 (permalink) Old 02-15-2010, 06:00 PM Thread Starter
Drives: 2003 Kia Sorento
hi. i'm new here and here out of desperation.
hubby is on his way home in our 2003 kia sorento and says the suv is stuck in 4wd low. (we had snow/ice here today and he needed to use the 4wd.)
ive read to him the other posts ive found regarding similiar situations but nothing's helped so far.
please advise.
thank u in advance!
jaydensmom is offline
post #2 of 14 (permalink) Old 02-15-2010, 07:21 PM
Drives: o7 Sorento 07 Camry,99 Pontiac
Could be many things. Fill out your profile and give us as much info about the truck(mileage,auto or manual tranny,etc)as you can. First check this forum for all the posts regarding your problem. This forum is a great information source. Check all of your fuses. Did this just happen or has it happened before? Could be something simple, could be expensive. Good luck.
fiddlersridge is offline
post #3 of 14 (permalink) Old 02-15-2010, 07:32 PM Thread Starter
Lightbulb Help!!!
It is a 2003 sorento with 146000 miles. we have never had this problem before. it is the 3.7L V6 automatic. what do the fuses have to do with the 4wd? the check engine light is on and so are both the 4wd hi and the 4wd low indicator lights!!
post #4 of 14 (permalink) Old 02-16-2010, 11:44 AM
Fuse check because one might be blown and not providing the electrical power to the switch/tranfer case motor to move the transfer case out of 4wd low.If you can get it to a code reader(a little box that the computer in your truck tells the mechanic what is wrong), have a shop or parts place(Advance auto,autozone) and have your check engine light codes read. Alot of times it will tell you a code,like P3003, you look up the code here in this forum and it will tell you what is wrong. This will go along way to finding out what is wrong with your truck, Anyone else want to weigh in?Good Luck!!
post #5 of 14 (permalink) Old 02-16-2010, 11:57 AM
Drives: 2010 Kia Soul, 1994 Ford Ranger
So let's get back to basic's. While vehicle is running put transmission in Neutral, hold brake pedal and then switch switch back to 2 wheel drive --- see if that does the trick, have have seen many of my customers not do these steps and you will not get it out of 4x4 unless you do (4 wheel low that is) -- see if this does the trick, if not may have issue with 4x4 module, bring to the dealer to confirm but that year has had issues with 4x4 module
WOOLLFF is offline
post #6 of 14 (permalink) Old 02-16-2010, 03:18 PM
Very good first step advise. Once out if this did the trick then rethink how you and hubby think 4LO works. Very few situations will you need 4LO. And if you use it wrong (many infact do) this is just what you get it to do JAM in LO. 4LO is in no way like AWD. Niether is 4HI but not as picky if you do it.
04SorentoLX is offline
post #7 of 14 (permalink) Old 02-16-2010, 04:26 PM
pistnbroke's Avatar
Drives: 2006 3.5 Sorento 4x4
stop ...foot on brake....neutral ....move switch ...wait 10 seconds listen for clunk...
Am a bit concerned you have the check light on ..if above does not work it dealer time .
if no go get under and look if you have ripped the wiring off the hi low motor ..its a bit like a wiper motor ....
pistnbroke is offline
post #8 of 14 (permalink) Old 03-12-2010, 12:47 PM
please advise.
thank u in advance!
Hi, I have an 2004 2.5 sx. I too had this problem. For a quick fix to get you back on the road is to disconnect the battery for a few minutes, and re connect. This will reset the solenoid, you are back in 4 high. Then its a replacment solenloid. Hope this helps.
kiabutler is offline
post #9 of 14 (permalink) Old 03-12-2010, 07:15 PM
pistnbroke's Avatar
Its actually an electric motor that moves a lever to change the gears in the transfer box Not a solenoid ....as stated must be stationary. neutral and give it time to move. Its only 2hi to 4 hi you can do on the fly ( air pump engages front axle)
post #10 of 14 (permalink) Old 01-21-2011, 09:52 AM
Fixed!
I had this problem last night. Couldn't get out of 4WD low. Who ever posted to pull the parking break, put it in neutral and rev the engine a bit, it did the trick!
Thanks for saving me a tow and $$$ at the mechanic.
maleaecu is offline
