Update on timing belts and chains
I was informed this morning that in the U.S. dealers are backing away from the 40k interval for timing belt change and going back to the 60k interval. Why? Internal records show that timing belts are not a wide-spread problem below 60k as first reported and to bring things in line across the board with dealers everywhere. If your U.S. dealer tries to get you to change at 40k, it is not corporate telling him to do it!
Other markets are using 60k as traditionally required by Kia and that is why gee6 did not see signs in his dealer's service/wait station areas.
I had reported that Kia was still using the 40k mark to change timing belts as this was still in the documentation I checked. It is no longer the case UNLESS you drive on dirt roads or in severe situations. Those require 40k service for timing belts. I am sorry I didn't get the concrete answer until this morning. I thought I had it.
Those new engines have timing chains and will be inspected at 60k and should not need servicing until 120k or later. This of course will raise some interest as the new 2.4L, 3.3L and 3.8L engines all use timing chains.
