Ecu Remapping - Kia Forum
post #1 of 8 (permalink) Old 04-26-2005, 07:14 AM Thread Starter
Ok I've seen lots of posts on ECU remapping
What is it?
Where do you get it done?
How much is it?
Is it worth it?
Does it invalidate the warranty?
Is it good for diesels?
Simeon is offline
post #2 of 8 (permalink) Old 04-27-2005, 05:43 AM
Ilan's Avatar
remapping the ECU is a way to get more power out of the engine, it is great for diesels.
BUT:
1. It will void your warranty.
2. In the long run the engine will be less reliable.
A better solution is to put an add-on between the ECU and the diesel pump, so when you go to service you just have to remove it.
You don't have to look far:
http://www.kia-forums.com/t3976-sorrento-diesel-tuning.htm
In anyway, don't understand that I recommend putting one, I do not.
I didn't put one and I am not going too, I find the Sorento GREAT as is.
I did see it work on a Mitsubishi Magnum, more power for sure, but much more smoke as well.
Ilan is offline
post #3 of 8 (permalink) Old 09-03-2006, 12:13 PM
ECU Remapping
ECU re-mapping for the diesel Sorento is the most efficient and safest way to extract about 30-35% more power and torque from your engine. I had mine done to a 2005 version and it was supposed to be downloaded from the ECU and flashed back through the interface terminal below the steering column. It was done by a Korean Hyundai motorsports specialist who comes to Malaysia once a month. The re-mapping is a full "check sum" method which means it is invisible to any service centers diagnostic equipment...it just doesn't show up! So my warranty is not affected as nobody knows it has been done!
During the re-mapping the process was supposed to take a few minutes but the ECU would not re-flash in-situ so the chip had to be removed from the ECU and re-programmed on a separate connector. The re-mapping program was prepared by Hiyundai Motorsports and was all done through windows on a laptop. Very professional I thought.
The Bosch ECU's planted in Sorentos only have 2 maps apparently, one for cold climates and one for hot climates, (or so he told me) so tuning it for performance makes no difference to the "durability" of the engine. In fact it makes the engine operate more efficiently. The process is completely reversible.
I toyed around with the bolt on tuning boxes, but these things are rubbish I think, and just trick the ECU into believing the engine is running slower than it is, thereby squirting in more fuel. If anything is like to damage your engine, these tuning boxes will in my opinion. The ECU re-mapping still uses all of the sensors so it works as "original" including temperature sensors and engine cooling. It cost me about GBP350, and I had the Sorento dyno tested which revealed about 182 hp at the wheels at 3500rpm and torque of 435N, at 2800rpm, (after fitting K&N air filter).
So far I have covered 6000km with the remapping and the engine is very quiet and smooth with a huge kick in it at mid range overtaking speeds, it will easily and quickly reach highly illegal speeds and just keeps on accelerating up the long steep hill to my home.
I believe the 2007 diesel powered Sorento is using a VVT or something turbo with similar outputs.
If you can get this re-mapping done I would go for it. My FC has also improved, surprisingly from about 9km/l to 11km/l.
torque54 is offline
post #4 of 8 (permalink) Old 09-16-2006, 06:41 AM
puttputt's Avatar
Drives: That would be nice
Gallery: 6
Interesting...but why is this so?
puttputt is offline
post #5 of 8 (permalink) Old 02-27-2007, 02:36 PM
Can i get my 2.5 diesel ecu remapped in britain?
roofrat is offline
post #6 of 8 (permalink) Old 02-27-2007, 04:25 PM
Drives: Sorento 2.5XS, Skoda Fabia, Ford Connect
Alfie168 is offline
post #7 of 8 (permalink) Old 02-03-2015, 08:35 AM
Ecu remapping for kia sorento petrol
I need ECU remapping for kia sorento 3.3l 2008 year, can anybody help me?
Narek is offline
post #8 of 8 (permalink) Old 02-03-2015, 11:15 AM
Tapeworm's Avatar
Drives: 2013 Sorento LX V6 AWD
Quoted: 249 Post(s)
Not without knowing where you live. Fill out your profile and people will.
Tapeworm is offline
