If the brake light switch has power coming out when button is pressed. I would check the connector for the brake light wiring. Their should be a plug around the tail light lenses. Check for corrosion in the bulb socket use steel wool or light sand paper to clean. Coat with grease if corroded.
You can use an ohm meter and check the wiring for high resistance. If a Northern vehicle with a lot of rust and poor wiring you can run new wire from tail light switch to the light socket.
