2004 kia amanti cylinder 3 flooded and smoking - Kia Forum
post #1 of 3 (permalink) Old 02-15-2017, 02:57 PM Thread Starter
Drives: 2004 Kia amanti
Hi my 2004 amanti started to run rough recently, there was a heavy smell of gas and it is smoking. Cylider 3 is getting flooded causing the misfire. There is a code for cylinder 3 misfire and a code on the throttle. I changed the spark plugs and the spark plug wires and it is still bad. Coil are also in good shape. Please let me know if anyone knows the solution to this problem
Davit97 is offline
post #2 of 3 (permalink) Old 02-15-2017, 03:05 PM
Drives: 09 kia spectra ex
Quoted: 95 Post(s)
Well from your own description, #3 cylinder flooding and smell of gas. I would say a stuck open fuel injector and will probably need to be replaced.
MIA KIA 09 is online now
post #3 of 3 (permalink) Old 02-17-2017, 12:00 AM
Drives: 04 Kia Amanti, 05 Kia Amanti, 10 Hyundai Genesis, 99 & 88 Suburban, 01 ES300, 91 E150, 89 S10 Blazer
2004 Throttle code? Do you own the code reader, or did you get it from a shop or parts store?
The throttle body is a Mitsubishi, and uses roller bearings that need oil. Remove the throttle body, remove the motor from the butterfly, clean the axle shaft bearings, spray white lube or drip motor oil in them, check to see that they roll very easily, then put it back together and check the resistance to finger pressure on the butterfly valve. If the butterfly valve was hard to move before you removed it and easy to move after you cleaned and oiled it, that code will not return.
Cylinder 3 is a bit more difficult. I like what MIA KIA wrote. You may want to take a compression test after you remove the spark plug, and then remove the injector. I think a trip to the boneyard may be a prerequisite first, to see if you can get the fuel rail system off of an identical 3.5 ENGINE and a throttle body. Having two of these cars makes it easier to work on one and use parts from the other.
danenzmann is offline
  Kia Forum > KIA Models > Kia Amanti & Opirus Forum > 1G Kia Amanti & Opirus Forum
