Being that I cant get an answer on my post maybe it can be answered here.
If the resistor craps out. Can it make the back of the fan switch get hot and melt the back of the switch. as this is the problem Im having. now when I use jumper wires on the connector that plugs in to the switch, that has 6 wires. I connect number 1 pin to the number 6 pin to get the fan on high. but also number 2 and 4 need to be connected to give power to the a/c. now when I do this the number 1 and 6 get really hot so hot you cant touch them and the wire starts to melt as did the back of the switch. is this a result from the blower resistor taking a dump. and if I get the resistor fixed will the over heating stop so I can buy another fan switch (would be the 4th one)?
