Originally Posted by pulsar86
The canister will most likely be the carbon canister that absorbs fuel vapours from the tank....
I believe that is what they said it was. Also, interesting note that wanted to mention -- as part of some of the repairs I'm doing on my 2001 Optima, I had to replace the spark plug wires which I did yesterday. After riding around with new wires for about an hour my check engine light came off and I thought on a whim it might have solved my issue with the fuel stuffs because the dealer said the CEL code was dealing with the canister. To my surprise it did! I'm guessing (not a car mechanic or anything) that the backup of carbon was causing that valve to stick, but once the emissions started working and burning again it burnt the excess carbon off and the valve works okay now.
I'm not sure if you mentioned your check engine light or anything, but if it has the CEL on, I would at least replace the wires (it might need them anyway as a tuneup) and see if it helps the issue any.
Also just so you know, my car has about 109,000 miles on it and the check engine light has been on since about 70,000 miles. Dealer quoted me around $400+ to get the CEL fixed and the fuel issue fixed. Doesn't hurt to try. Only takes about an hour and $50.
