Mine does this too, mostly when putting gas in the tank though
We may have the same problem. It usually happens when I drive from home to the gas station a block away (cold). Put any amount of gas in the tank then try todrive off.
It won't start until I slam the gas pedal, then I have to keeplthe RPMs high and jerk it into to drive. Once I have driven for just maybe 20 yards it will idle fine. Otherwise it will just die out on me unless I keep the gas on it.
So far, it only seemed to happen when I put gas in after a short and cold drive (not cold outside, cold engine). But it happened when it was warmed up too although right after parking for a bit.
Not sure what the problem is, I've put a few bottles of Chevron in the tank but it didn't seem to help.
I'm wondering if its a vacuum hose somewhere? Why would putting 2-12 gallons in the tank affect its ability to start?
I have a 2001 Optima.
