Originally Posted by garster
the motor is a 2.4 litre auto
Again see above as it might have one. Why do you need to know? Did someone tell you it needs to be replaced now? Did you go to the parts store and ask for a TB and they asked if you need the OIL PUMP belt as well? If so are you doing the job yourself? If these LAST TWO questions are hard to answer you should not be doing the job. As
1)You do not have the proper book/manual to look at which would have told you what you need to know already with pictures.
2)See 1 and not a job for you to try to tackle with your skill level.
If the first question is yes then, a trip to the parts counter at the dealer is a five min verifaction. Look up the Timing/Oil Pump systems info. If they show you on your 2.4 got a TB (valves) and a OIL PUMP drive TB belt you do. Many times Auto Parts store info is wrong. Dealer microfishe/Sat link is always right. That is NOT to say the part numbers are or right upto the min. Sometimes supercedes lag. But the fact if or if not you got a belt at all is not wrong.
