» Sponsor Links
»Garage Storage and Cabinets
Old 08-20-2006, 07:02 AM   #1 (permalink)
walrus
Default fuel injecors not working
2001 optima, NO Start
This is my bosses car and I would appreciate any help. I checked the online service manual and it kinda sucked. No Detail of how the FI system works.
I found that injectors on cylinders 3 and 4 were not working(getting switched). With the plugs out cylinders 1 and 2 were wet and 3,4 dry. I hooked a test light to the plug on both 1,2 and they both lit when I cranked her. Nothing when I tried 3,4.
I assume that the ECU controls all this and that there is no other reason they are not all working? Do ECUs go out a lot on these?
One other thing that bothers me is that the fuel pump runs whenever the key is turned to the run position. Most cars I am aware of will run the fuel pump a few seconds to build the fuel pressure back up and then shut off when the key is turned to run and before you start it.
Thanks for any help. My speciality is german cars. I am not finding a lot of info for Kias.
walrus is offline   Reply With Quote
Old 08-20-2006, 10:11 AM   #2 (permalink)
ahfrederick
ahfrederick's Avatar
Drives: 2004 Kia Optima
Send a message via AIM to ahfrederick Send a message via Yahoo to ahfrederick
Well you can ask 1fastkia about it, but I think he might say what I'm about to say.. I believe that the third and fourth injectors have gone bad.
My suggestion? Take them down to either an autoparts store or a familiar garage (with mechanics that you KNOW) and have them tested again. Otherwise, it might be time to replace those injectors (but I am NOT a mechanic, and haven't dealt with this type of situation.. so I could be wrong).
ahfrederick is offline   Reply With Quote
Old 08-20-2006, 06:57 PM   #3 (permalink)
walrus
I appreciate the thought but the #3 and 4 injectors are not working because they are not getting power to actuate them. You may have the same problem.
Old 08-20-2006, 09:07 PM   #4 (permalink)
Classic boy
Did you check the fuel injection relay, although I couldn't imagine that the car would have 2 relays one for cylinders 1&2 and one for cyls 3&4, but you never know, if not then its either a ecu gone bad or damaged wires somewhere between the injection harness and the ECU.
Normally the injecters have 12V+ at them when the engine is on or cranking, its only the earth is switched on/off by the ECU for pulsing, if you can confirm whether 12V+ is at the injector then you know it is wiring or ECU at fault if there is no 12V+ then the power supply is faulty and the ECU is probably OK.
Old 08-20-2006, 09:45 PM   #5 (permalink)
walrus
Yeah, I checked the fuses. There is only one for all the injectors. Thanks for the confirming the ecu controls the ground. I will have to check it out again and see which I am not getting.
Any Idea where to get a wiring diagram that shows the wire colors? The one here, http://www.kia-forums.com/1g-2g-2001...gentis-optima/ is not very good.
Old 08-20-2006, 11:31 PM   #6 (permalink)
ahfrederick
OH trust me.. I don't have ANY problems with my Fuel System!
During my drive from virginia to texas, I'm averaging around 30MPG on the highway..
Old 08-22-2006, 04:59 AM   #7 (permalink)
walrus
I checked the power and grounds. With the key on I get power to all the injectors so that means I am not getting ground from the ecu to the 3,4 injectors. On a side note the codes were pulled and it showed a camshaft position sensor fault.
Old 08-24-2006, 01:20 AM   #8 (permalink)
Classic boy
IMHO I think you problem is you camshaft sensor fault, if I remember the design logic without that signal you will get no injector pulse.
BTW
I have a hardcopy manual for the RH drive sedona/carnival and it is just as poorly written as the online manuals.
Old 08-25-2006, 05:38 AM   #9 (permalink)
walrus
Well, new camshaft position sensor did not change anything. The reason it may have had that code is because I think I cranked it with it unplugged. Somebody else scanned it and probaly didn't reset the codes, crank again, and rescan it.
I really didn't expect that to fix it as it 1,2 were getting actuated. It makes no sense to me that half would work and not the other two if it were that. They open and close in a sequence matching the plugs firing, (excluding the waste firing).
Classic Boy, the only manual I found was the one I linked to. Is there anything else out there with a wiring schematic or troubleshooring chart? Something explaining the fuel injection system?
Old 08-25-2006, 09:12 PM   #10 (permalink)
Classic boy
Does the camshaft sensor need to be timed to the cam? I don't know on the 2.4 engine I have not worked with this engine previously.
The only online manuals I'm aware of is the global way manuals.
You can sometimes buy repair manual CD's of ebay for some Kia models.
