Originally Posted by TwinTurbo
The check engine light will be on if there is a code. The knock sensor is just that a knock sensor, it only senses a certain frequency. But yes it could be bad. Before you pay some to check it out do some simple things to see if that helps. Could be water in the fuel,could be carbon in the combustion chamber, like I said before it maybe a number of things.
The knock sensor does a little more than detect knock for the sake of detecting knock.
The engine management system uses that info to trim the ignition timing curves in its program to stop the knock, it will continue to retard timing to stop the condition.
So if it is knocking (which is another term for pinging) the engine management is not doing its job correctly, because modern cars with a knock sensor should never ping.
BTW you can have codes without the engine light being on. NOT every code will bring on the lamp only a certain class of codes as determined by the maker will bring on the lamp.
