most of the optima's doesn't have an external filter, the internal filter is just a screen and doesn't have a scheduled replacement, as far as the trans fluid it takes Kia sp-III fluid, which is the same as mitsubishi diamond 3, it is recomended that the transmission fluid be flushed every 30,000 miles it is better to use synthetic but as long as it is changed regularly sp-III is ok, as far as dextron 3 never use it, it is not compatible with the friction material of the clutch disks and cause premature failure
Jeremy Owens
Muscatell Kia
