At 65K Miles 02 Optima I have done the trans fluid complete
change for around $230 at an Xpress Lube.
Which is where I get oil changed every 3500 miles.
Trans fluid was done around 55k or so.
Airfilters each 20k or so.
Front brakes at 60k. Rears were amazingly un-worn.
Have had to buy two tires so far.
Soon to look and see if there is a fuel filter
(as the shop manual shows) or no fuel filter (as some people are reporting).
Also going to gather up timing belt and water pump and go after these.
I have a new serpentine belt also, will do that with the others.
