Optima Radio Has No Sound - Kia Forum
post #1 of 8 (permalink) Old 01-24-2006, 07:17 PM Thread Starter
My radio sound stopped suddenly for no apparent reason, I checked the audio fuse under dash and it was ok. I pulled the radio out and took it apart to try to find an internal 5 amp fuse (label on radio indicates 5 amp fuse) but did not find one. I bought another exact radio on ebay ($10.50) and it still does not have any sound. I checked the rear speakers and they seemed ok. Is there another fuse somewhere that I am missing? Has anyone else had this problem? Thanks for any help you can give me!
Joe Comeau is offline
post #2 of 8 (permalink) Old 01-24-2006, 09:32 PM
KiaMech's Avatar
Drives: 2003 Kia Sorento
Does your Optima have an amp? I think just the EX's have the amps, but I've seen a couple of these go bad with the exact same symptoms. I believe the amp also has a separate fuse under the hood, so be sure to check that too if you believe you have an amp.
KiaMech is offline
post #3 of 8 (permalink) Old 01-24-2006, 10:14 PM
ahfrederick's Avatar
Drives: 2004 Kia Optima
Send a message via AIM to ahfrederick Send a message via Yahoo to ahfrederick
When you checked the rear speakers.. were the connections TOTALLY in tacked? Because I went through the same thing when my driver side rear speakers connector was split from a big package I had slipped in the trunk and hit the speaker.. but yeah.. that's just me.. just thowing that out there! Hope that helps!
ahfrederick is offline
post #4 of 8 (permalink) Old 01-25-2006, 07:38 PM Thread Starter
I have an SEV6 model. I have no idea if there is an AMP (as amplifier ?). Where under the hood would it be located and what does it look like?
post #5 of 8 (permalink) Old 01-25-2006, 07:46 PM Thread Starter
The connections on the speakers looked fine, I unplugged them and plugged them back in, the wiring appeared to be connected with no visable breaks.
post #6 of 8 (permalink) Old 01-25-2006, 08:14 PM Thread Starter
Good news! The sound in the radio is working. I checked the fuses under the hood and found a one that said "AMP", I checked it (20 amp) and it was blown. I plugged the radio back in and it is working fine. Thank you for your help. Just a side note; when I brought my car to the KIA dealer they said the warrenty was past 3 years and the radio was not covered, however they could replace it for about $1,400. I told them to "you know what" themselves. Thanks again!
post #7 of 8 (permalink) Old 01-25-2006, 09:41 PM
KiaMech's Avatar
OEM companies are REAL proud of their radios and amps. The Optima amp isn't much less than that at the dealer cost, so they were trying to cut you a deal (if the amp was bad, but if they knew it was a fuse then they would have screwed you out of $1400) The radios are over a grand also, as are GM radios, Mitsubishi radios, etc...
Anyway, glad you found your problem.
KiaMech is offline
post #8 of 8 (permalink) Old 01-25-2006, 11:13 PM
Awesome.. glad to see that it's working again.
