Old 05-26-2006, 10:58 PM   #21 (permalink)
ahfrederick
ahfrederick's Avatar
Drives: 2004 Kia Optima
Send a message via AIM to ahfrederick Send a message via Yahoo to ahfrederick
Hmm.. I've found that the bulb that you mentioned is an "HIR" bulb. "HIR" stands for Halogen Infared Reflecting. You can check out more info here: HIR Headlights 9011 9012 Bulbs
ahfrederick is offline   Reply With Quote
Old 06-02-2006, 06:00 AM   #22 (permalink)
04lxoptima
04lxoptima's Avatar
Send a message via MSN to 04lxoptima Send a message via Yahoo to 04lxoptima
Ok. I knew what the bulb was I was just wondering why it has that instead of a H7 and how they got it in there and how come I do not have a H7 harness on the High Beams?
Thanks greatly though.
04lxoptima is offline   Reply With Quote
Old 06-04-2006, 09:13 PM   #23 (permalink)
ahfrederick
That's wierd, since OSRAM/Sylvania has the high beam as an H7. NEWayz, I don't really have to worry about that since I've installed the 6K HID Kit!
Old 08-31-2006, 11:19 PM   #24 (permalink)
FlipMan
Mine are the same way for my 2003 Optima SE. When I went to change my high beams they were a totally different design from the H7 low beams. I was swapping out all my headlights to H7 7000K HID Hi-Lites when I noticed the difference. According to everyone and even some e-Bay sellers the high beams are suppose to be H7's like the low beams. But they are not, something totally different with the Philips logo. Even the harness like you mentioned is totally different. In fact it looked like a pain in the a$$ to get out so I left them alone. Low beams turn off when you use the high beams anyway so it's not like anyone will notice I have mix matched low and high beams.
What's the easiest way to take out the fog light bulbs? The manual says the cover should unscrew to get to the bulb. But I don't think it's possible to do that and get it through the hole. Any suggestions?
FlipMan is offline   Reply With Quote
Old 11-02-2006, 05:53 PM   #25 (permalink)
Nate52687
Anyone have any info on actually removing the headlight assembly on an '01?
Nate52687 is offline   Reply With Quote
Old 11-26-2006, 01:21 PM   #26 (permalink)
Heywood
There was something about removing the other bolts and pushing in on the side, if memory serves (extra disassembly beyond the obvious). Sorry I can't be too much more helpful, it's been a while.
Heywood is offline   Reply With Quote
Old 03-08-2007, 01:45 AM   #27 (permalink)
ahfrederick
So no new updates for the 2001?
Wish I could help but my setup is a bit different.
Old 05-29-2007, 09:21 PM   #28 (permalink)
rsimes44
Question headlight replacement
I'm glad to know which bulbs to use, but how do I get the danged thing out? I have a 2006 Optima and the bulb burned out. I'd like to replace it. The book says to release the locking wire, but HOW?
rsimes44 is offline   Reply With Quote
Old 05-31-2007, 11:59 PM   #29 (permalink)
ahfrederick
You have to first press it in towards the bulb then push down and under the tooth/hook (whatever you'd like to call it). That will release the bulb. I really do wish I had a picture to show you, but I don't. Sorry. Hope that helps.
Old 07-27-2007, 02:01 AM   #30 (permalink)
BargeCrew
Default '04 Bulb Replacement
I'm just now getting around to installing the H7 super white bulb's for my Optima and ran into a brick wall. The harness if I may looks a bit discouraging so I pussed out. Thought I'd find something here on the forum's before screwing up something in my headlight assembly's. I'm sure it's a no brainer but I'm somewhat challenged when it come's to car's, go figure.
So I removed the black thread mounted cover that sits behind the bulb's and found two phillips head screws on either side of the plug. Can I simply pull the plug? There's also some sort of metal clippy looking thing I played with but wanted to be sure before making a mistake.
I read the entire thread and got a few pointer's but what's with the H7 bulb's only lasting 1100 hours was it? It is even worth the swap if I'll have to be replacing bulbs every few months or so?
BargeCrew is offline   Reply With Quote
