Old 01-22-2005, 11:51 PM   #1 (permalink)
magnificentbastard
Anyone else having problems with getting your gas gauge to display "Full" when you fill up with gas? Mine only seems to go to 3/4.
magnificentbastard is offline   Reply With Quote
Old 01-23-2005, 07:22 AM   #2 (permalink)
1fastkia
Drives: 2002 Mustang GT
the 98-99 sephias had that problem and they eventually recalled it dunno if they will with this though. Id fill up and it would stop at 3/4. they replaced some sensor and it worked fine after!
Old 01-24-2005, 04:12 PM   #3 (permalink)
magnificentbastard
Thanks.
Old 01-27-2005, 08:46 AM   #4 (permalink)
1fastkia
this was the recall
Defect Summary: VEHICLE DESCRIPTION: PASSENGER VEHICLES. MANUFACTURING CHANGES WERE MADE TO THE ORVR SPRING FORCE AND FLOAT WIRE LENGTH REDUCING THE VALVE ANGLE. CERTAIN VALVES CAUSED FUEL SHUT OFF BEFORE THE TANK REACHED 95% OF NOMINAL CAPACITY.
Consequence Summary: THIS WOULD CAUSE CUSTOMERS TO ADD MORE FUEL TO THE TANK CAUSING FUEL SPILLBACK OR SPITBACK FROM THE FUEL FILLER NECK.
Old 02-13-2005, 08:09 PM   #5 (permalink)
hattee
hattee's Avatar
Seems this is one of the more significant problems some Optima owners faces. My gauge began to under read after 30,000km and got C&C replaced the gauge float switch at 40,000km and fixed.
By any comparison, this is very mild defect. The other could be the maintenance-free battery that fails probably before 40,000km. Personally, would prefer large conventional wet-acid battery which has better latent heat absorption during overcharging without damaging the lead plate in hot climate conditions (unless getting the premium maintenance-free like Optima battery).
hattee is offline   Reply With Quote
Old 02-13-2005, 08:10 PM   #6 (permalink)
hattee
hattee's Avatar
Seems this is one of the more significant problems some Optima owners faces. My guage begin to under read after 30,000km and got C&C replaced the guage float switch at 40,000km and fixed.
By any comparison, this is very mild defect. The other culd be the maintenance-free battery that fails probably before 40,000km. Personally, would prefer large conventional wet-acid battery which has better latent heat absorption during overcharging without damaging the lead plate in hot climate conditions (unless getting the premium maintenance-free like Optima battery)
