Old 06-22-2009, 06:21 PM   #1 (permalink)
millhouse6666
Default Rear wheel bearing change
I have to do my rear wheel bearings on my 2003 Rio. Just wondering if anyone has a drawing on the assembly. I would like to take a look before I take the wheel bearing out.
millhouse6666 is offline   Reply With Quote
Old 06-22-2009, 08:04 PM   #2 (permalink)
KiaMTBrider
Drives: 2003 Kia Rio
I have a 2003 Rio. The dealer supposedly replaced the right rear bearing after it went bad at 90,000. It went bad again 10,000 later after the 100,000 was up. I replaced it this time myself. Its easy as the inner and outer bearing only fit one way. Just pack them with grease good. And put in new races and seals. The dealer obviously didnt replace both inner and outer when he did mine. There were 2 different types of grease. I have since gave this dealer a bad rating on Repair Pal.
KiaMTBrider is offline   Reply With Quote
Old 06-22-2009, 08:11 PM   #3 (permalink)
KiaMTBrider
I forgot to add that at over 107,000 miles, that was the only bearing to go bad so far.
Old 06-22-2009, 10:56 PM   #4 (permalink)
Pacosworld
Pacosworld's Avatar
Drives: 1990 VW Corrado Supercharged 1.8L, 2000 Dodge Grand Caravan
Heres a pic from http://www.kiatechinfo.com. If you haven't already, sign up for a free user ID. Its the same info Kia techs use. Good luck.
Mike AKA Paco
O'Brien Kia of Urbana
Pacosworld is offline   Reply With Quote
Old 06-23-2009, 11:13 PM   #5 (permalink)
millhouse6666
I did sign up and couldnt find anything. Will try again but your help is greatly appreciated
Old 07-02-2009, 11:05 AM   #6 (permalink)
alio40
Drives: 2001 Kia Rio 5-speed
Send a message via Yahoo to alio40
the rear wheel bearings are crap from kia. get Timkin replacements. any industrial bearing supplier can order you a set. trust me, well worth the upgrade.
dont forget to pick up new outer races!
as for doing it... please search the forums before you post.
this link may be for drums, but they do contain the bearings
http://www.kia-forums.com/1g-2g-2001...tml#post156210
bearings fail from one of 3 reasons :
* Vibration
* Loss of Lubrication (too much lube prevents heat dissipation)
* Over Torqued (or under torqued if they need to have a 'preload' torque, which most front wheel bearings require)
Observe ALL
Focus ONE
alio40 is offline   Reply With Quote
Old 09-08-2009, 11:43 AM   #7 (permalink)
kia6336
Default rear bearing
Hi ,
Did you use original Kia bearing for the replacement? I replaced my 04 Kia Rio with the OEM version of wheel bearing and the humming noise came back just 2 to 3 months of driving. What is the bearing model or reference that you are using?
kia6336 is offline   Reply With Quote
Old 09-09-2009, 03:26 PM   #8 (permalink)
alio40
the original Kia bearings are quite cheap in the quality department... i do recommend the Timkim brand.
take the bearing to an industrial bearing supply store, they will match it up for you.
Motion Canada is where i picked up mine.
Observe ALL
Focus ONE
