Originally Posted by treblot
Can faulty thermostat cause no power to fan motor?
The thermostat controls the flow of coolant, so it's not the cause of of the fan not running.
The fan is controlled by a thermal switch - try find this and jumper it and check if the fan runs - if so then this thermal switch needs replacing.
Edit: I can't find the electrical schematics for the Rio, but it may be the latest control scheme which means the ECU monitors the temperature sensor and switches the fan relay as required - if it's this arrangement then lifting the wires of the sensor should make the fan run.
