Hello all
i have a 2001 reo and it keeps kicking the code for the VSS sensor (code501) so 1st we checked the connector and it was not looking good so we cleaned it and cleared code....still kicked the code...then we changed the sensor and cleaned connector agen.....still kicked the code.... so the last thing i have tryed is it solder the wires to the sensor that did not work eather
so 1st is there 2 VSS sensors(some one told me there maybe) and if so where is 2ed one ....the one i see is on the top of the crankshaft
2ed if there is only one what can i do
this car has bin down since feb not that it will not drive ... it drives fine... it's out of inspection and i dont want another $130 in fines
oh i forgot to say
yes the speedometer is working fine ....also it's a stander 5speed trans.
thanks
