Hi,
I have a KIA Rio 2002. For some time now, my car keeps blowing the METER fuse, specially when making a tight right turn. I took it to the dealer, and they said they could not reproduce the fault after riding it extensively. As I drive out of the dealer, at the right turn, it did blow again!! Later at home I found several spent fuses at the door pocket, so I suspect the did reproduce the fault, but could not figure it out. Has this happened to anybody else? Any hints? As an extra datum: the engine mounts are in need of replacement, but they wanted $350 to do it...No way! I think it is related to the blowing fuse as maybe the shifting engine might be touching some cable. I just need a place to start looking. Thanks!
