Well you need to replace the airbag control module, and I would replace the impact sensor. The clock spring in the steering wheel should be fine. Now since your car is a single front airbag the ACM most likley is different from US cars since we have dual front bags. G1/G2 Rio's did not use dual stage airbags, airbag deployment is based on the crash sensors and airbag's deploy at speeds much lower than IIHS,DOT-NCAP, EURO-NCAP etc All the tests are virtually identical, and speed differences are negligible, the real difference is China, India, and the old Russian test that is being phased out, as Russia goes Euro-NCAP.
Even if the airbags are identical USDM and S.E. Asia will the Indonesian customs allow the bag to be shipped in, remember airbags are classified as an explosive. Most carriers do not want the hassle / liability
