Kia-Forums.com is owned and operated by AutoForums.com, Inc. Kia-Forums.com is an ehthusiast website dedicated to the discussion of Kia Vehicles, Kia Family Cars and Kia SUVs. Kia-Forums.com is completely unofficial and is not endorsed in any way by KIA Motor Corp, its affiliates, or its subsidiaries. KIAŪ is a registered trademark of KIA Motors Corp. in Canada, the United States, and in other countries around the world. No challenge to the status of KIAŪ's registered trademarks is intended.
ŧ Wheel & Tire Center
» Sponsor Links
»Garage Storage and Cabinets
Old 07-12-2008, 08:51 PM   #1 (permalink)
lorolia
Default ISC strange test?
Iīve had time today to check my car and following the manual for fuel control system I started to do some tests to the ISC (which I think is causing this suddenly stall)
One of the test says:
With Ignition OFF, disconnect ISC valve connector.
Then Ignition ON (engine OFF) and measure voltage between harness connector B22-1 (to ECM) and GND.
Is measured voltage less than 0.5V?
If Yes Go to step 2.
If No Short to battery voltage in connector B22-1.
Repair as necessary.
Then I measured voltage of ISC connector and ground and it measured 3.63 volts.
But Iīm a little bit confused here:
I went online and looked for rio 2002 procedure to do this test (which has the same 1.5 Liter doch engine as the 2005 model I own) and it says exactly the same thing but the procedure for rio 2005 says something different:
Turn ignition to OFF and disconnect IACV connector and ECM connector.
With ignition ON, measure voltage of IACV opening coil circuit between IACV harness connector and chassis ground.
1) Specifications: below 0.5V
Is voltage within specifications?
Yes: Go to step 2
No: Short circuit to battery between IACV harness connector and ECM harness connector.
So Iīm confused! the 2005 model for USA says to disconnect the IACV and ECM connectors
what is the right way to do the test?
lorolia is offline   Reply With Quote
Old 07-13-2008, 12:26 AM   #2 (permalink)
lorolia
maybe someone wants to make this favor and measure the voltage in their isc (iacv) connector (pin number 1 and ground) and post numbers if itīs measuring less than 0.5 volts with ignition on
thereīs something strange in this the opening side measures 3.63 which is more than .5 volts and the closing side measures .37 volts which is under the spec.
I donīt understand why the manual tells to disconnect the ecm connector too and make the test that way...it simply doesnīt make any sense to me (please correct me if I wrong)
Old 07-13-2008, 01:47 AM   #3 (permalink)
lorolia
Default I have another question
when you go to parts catalog it shows you 2 different part numbers for ISC
mine has 0K9A220660A
but thereīs another with this part number: 0K24720660
and thereīs a remark for both of them: selective use
whatīs that "selective use" kia is talking about?
itīs the same for TPS there are 2 part numbers available and the remark says: "selective use":
0K24718911
0K30A18911
whatīs the difference? maybe regions of the world too? or climate where the sensors are going to perform? does anybody know? just being curious
anyway hereīs a picture of my ISC
Old 07-13-2008, 03:52 AM   #4 (permalink)
Raven1210
Raven1210's Avatar
Gallery: 14
sorry I don't get on how this part works so i cannot help you. I don't even know where to start. When it comes to test pin # and ground
Old 07-13-2008, 10:22 AM   #5 (permalink)
lorolia
I will help you to help me...
you have to disconnect the ISC connector
(take a look at the pictures)
Old 07-13-2008, 10:36 AM   #6 (permalink)
lorolia
...then you have to measure voltage in each of the 3 connector terminals with ignition ON (engine off, not running)
here are more pictures
in my car the wires go as follow:
the withe wire is pin number 1
the red wire is pin number 2
the green wire is pin number 3
Old 07-13-2008, 11:05 AM   #7 (permalink)
lorolia
...turn ignition to "ON"
connect your multimeter positive lead to pin number 1 (white wire of the ISC connector) and connect the negative lead to ground (which is basically the chassis of the car) and measure voltage....how many volts measure yours?
Old 07-13-2008, 11:55 AM   #8 (permalink)
lorolia
continue to measure voltage in the remaining 2 wires of the ISC connector
red wire expected voltage value according to manual : B+ or 12 volts (I just donīt know why they put B+....itīs 12 Volts battery voltage...sounds better to me)
Old 07-13-2008, 12:04 PM   #9 (permalink)
lorolia
...and finally
measure green wire (pin number 3) expected value: less than 0.5 volts (according to manual)
Old 07-13-2008, 03:08 PM   #10 (permalink)
ron1004
Drives: Kia Elan
You should measure B+ (12V) only on pin 2 and as the book says < 0.5 V on the other two pins.
Pin 2 will supply power to the two ISC coils (the open and close coils are internally connected) and the ECU will pull the other side of the coils down to ground, using a alternating signal to position the ISC.
The ECU will change the duty cycle on the open and close coils depending on which way it needs to go.
Typically if your ISC is connected and you turn on the ignition then it should buzz due to the alternating power that the ECU uses for the ISC.
