what if mine measures around 237 mm Hg at idle? this is according to the hi scan pro device (connected in the diagnosis connector in the engine bay)
is it bad if it measures that?
This car has no OBD-II connector just the "diagnosis connector" or maybe you know it with the "data link connector" name.
Something else I´ve noticed is it won´t give me as many info or codes showing something is wrong as in usa version model.
I now have the correct translation to english for the symptoms my car is showing...the word is "stall".
My car stalls driving in a normal hot and sunny day and when I demand power from it pushing the gas pedal...it makes this stalling for about 1 or 2 miliseconds
this has happened only when engine is fully warmed up and it will do it once or twice in a month period.
I´m also getting misfires and I have the sensation it has poor acceleration on demand.
what else should I check/change?
They alredy change the computer once and I´ve made this list of sensors I´d like to change:
1-TPS
2-ISC
3-CKP
4-Knock
5-CMP
6-ECT
What do you recommend?
I really want to fix my car...any idea?
I already changed the t-map sensor and noticed no improvements.
Every time they connect the kia scanner it doesn´t show any codes.Now I know why. Because this "siemens" computer is made to only show this codes: (maybe because emissions are not important at all here)
P0107
P0108
P0112
P0113
P0117
P0118
P0122
P0123
P0131
P0132
P0135
P0201
P0202
P0203
P0204
P0325
P0335
P0340
P0440
P0606
P1505
p1506
p1507
p1508
Maybe the program that carries the computer is different or maybe the brand beacause I´ve seen on ebay kia rio computers with the "bosch" brand but this one is siemens.
Also if you have the kia microcat EPC it will show you different part numbers of PCM or ECT for different regions all over the world
