As far as end user reliability is concerned you will not get the reliability from a rio that you would get from a Ford Escort or Focus. Most of the people here will disagree, but Consumer Reports, J.D. Power etc do not lie. Back to your gas tank issue, I would check the fuel line fittings, you can remove the rear seat bottom cushion and there is a plate in the center secured by four screws, remove the screws look at the lines both with the car running and the car off. it is possible a line needs to just be relocked in place or an o-ring is bad, even the fuel pump o-ring may have dried out and is allowing gas to splash past it. If it occurs during fill up's then the fuel filler neck to tank hose may be the culprit. If indeed it is a gas tank a salvage yard may be a good option, if you would like a new tank check with the radiator wholesalers in your area, the ones in my area as well as other areas I have lived in have carried gas tanks along with their lines or radiators, condensors etc.
Generally a bad leak is easy to spot as the drops are present on the bottom of the engine, trans, or cross-member, you just follow the drip to the seal, gasket, etc from where it originated. Generally if the leak is on the driver's side it is transmission fluid, if it is on the passenger's side it is motor oil, but could be transmission fluid as it is used as PS fluid, it could also be antifreeze.
