You add Tranny fluid at the tube where the dip stick is for the tranny NOT THE DIP STICK FOR THE ENGINE OIL. Only SPIII transmission fluid is recommend, but if you can't find it in the sticks where you live I would use Castrol Import Multi-vehicle ATF fluid. Its fairly cheap and will get you to the repair shop, personnally I'd stay away from the dealer and use a private shop with licensed mech. My deallings with the dealer has been that they are way overpriced, but thats just me "cheap I guess". BTY you'll need a funnel to pour the tranny fluid in. Good luck
