Originally Posted by mark458
...non-return vavle? I dont see any valve in that line. Also I have sprayed every square inch of the intake/vacuum system and found nothing.
And yet all the error codes Im getting point to vavuum! Im about to throw this thing in the lake and file it stolen. This is the LAST kia I will ever buy unless someone can tell me exactly what to fix.
Often the non-return valve is on the end of the vacuum pipe and it plugs into the brake booster, much the same as the PCV in the camshaft cover.
From the KiaTech site in my sig:
CHECK VALVE
The check valve is pressed into the vacuum hose. The arrow on the hose indicates the direction of hose installation (toward engine).
1.Remove the clamps and remove the hose (with the internal check valve).
2.Apply a suction and pressure to the hose from the engine side. Verify that air flows only toward the engine. If the airpasses in both directions or not at all, replace the vacuum hose (along with the check valve).
http://www.kiatechinfo.com/data/manu...G/bj2c018a.gif
