it was the head gasket, i called Kia and they said it was under warrenty because it had been replaced last april for the exact same problem and is still covered under warrenty, recommended that the cylider be redone for $250 while they were doing it, worthit tom me. Now if I can just get my ignition problem figured out.
Sometimes when I try to start it you have to turn the ignition on and off several times before the fuel pump kicks on and starts it, at the kia dealership they said it was probably the fuel pump which I knew wasn't the problem because I just replaced it. Any ideas anyone?
