Fuel Evap Purge Solenoid Testing -
1.Disconnect vacuum hoses from EVAP canister purge solenoid valve.
2.Verify that no air flows through valve.
3.Disconnect valve connector and apply 12 volt battery voltage as shown in figure.
4.Verify that air flows through valve.
5.If no air flows, replace the valve.
6.Reinstall valve connector.
7.Reconnect vacuum hoses.
Cannister Close Valve Testing -
1.Measure canister close valve resistance.
Resistance:Approximately 24Ω ± 1.5 at 68°F(20°C)
2.If not as specified, replace the canister close valve.
