03 RX-V Rear Bumper Removal
Had a dent/tear in the left corner of the rear bumper panel and decided I would fix it myself. Thought it would be easier to deal with if the panel was removed. Went online to the global tech manual where I found what I thought was the procedure to remove the rear bumper. It would take you fifteen seconds to realize there are obvious errors in the procedure given because just reading them shows they make no sense but further still I realized they are not relevant or accurate to the RX-V. I struggled like crazy but finally got it off without damaging it any further and figured it might be helpful if I wrote down the real procedure for the RX-V. I will try and do a decent job and include photographs and then post procedure on here. Let me get repairs done and re-install in case I come across more problems and then I will submit. If anyone has quesitons in the meantime. Give me a shout. I have zero tech skills but am determined to learn. My mistakes and experience could save you the pain.
