1.1 millimeters which I believes converts into 45 thousanths of an inch. I used some different plugs, rated the same for my rio, and they just didn't wanna work right. I had to o back to the correct NGK plugs. Eventually, I want to get the NGK Irridium plugs. They will work just fine in the rio as the rio was designed to work best use the NGK plugs. The reason I plan on using the iridium plugs (they are about $11 each) is I plan on going forced induction. I will also be installing an MSD DIS 2 ignition, MSD GM Coil packs, and bigger wires. There will be much more air and fuel in the cylinders, so a better spark from that whole setup will add power, but to a N/A car, it won't make a differance.
Matt
2004.5 Kia Spectra LX - Spectra Rocket
2003 Kia Rio - Firestarter - Traded
